Activating SOTI MobiControl Offline
The first time you access the SOTI MobiControl console, you will be prompted to activate SOTI MobiControl by providing a valid registration code. If you do not have a valid registration code, you can visit www.soti.net to sign up for 30-day trial registration code or contact your SOTI representative for a full registration code.
To activate an offline deployment of SOTI MobiControl:
- On a computer that can access the internet, navigate to your SOTI MobiControl instance's console web address.
- Click Activate Offline.
- Open a new browser tab or window and navigate to https://activate.soti.net/MCActivation.
				Enter the following information:
				- Registration Code
- Installation ID
- Product Version
 The Installation ID and the Product Version can be found in the Administration Utility under View Product Details.
- Click Get License to generate the license file. Save it to your computer.
- Return to the SOTI MobiControl Offline Activation browser tab and upload the license file.
After SOTI MobiControl is successfully activated, you will be asked to enter administrative credentials and then you can begin managing your devices.
