Disabling Activation Lock
Activation lock is automatically enabled by SOTI MobiControl on supervised iOS devices. You can disable or enable activation lock for individual devices or whole device groups.
To disable or enable activation lock on an iOS device:
  1. Click the device name of the device whose activation lock you want to disable or enable to open the Device Information panel.
  2. Move to the Configuration tab.
  3. Under Advanced Configurations, open Activation Lock Settings.
  4. Enable Override Settings Inherited from Parent Group and disable or enable activation lock on the device.
  5. Click OK to save your new activation lock settings.
To disable or enable activation lock on all iOS devices within a device group:
  1. Right-click the device group that contains the iOS devices that you want to disable or enable activation lock on and select Advanced Configurations.
  2. Under Advanced Configurations, open Activation Lock Settings.
  3. Disable or enable the activation lock setting.
