Add/Edit Application Run Control Entry
In this dialog box you specify the device restriction you want to add to the Application Run Control list.
Target Type | Select the target type of the restriction.
Note: On Windows Phone and HoloLens, Modern Application is the only target type available.
Policy Type | Select the policy type of the restriction.
User or Group SID | Enter the Windows user or group security ID you want the restriction to apply to, or select a predefined user or group security ID from the list. |
Name | Enter a name used to identify the restriction. |
Description | Enter a description for the restriction. |
