Client PFX Certificates
Use a Client PFX Certificates configuration to distribute Client PFX certificates to Windows Modern devices. You can select an existing certificate or you can select a template that SOTI MobiControl will use to dynamically generate a certificate that is specific to each user and device. For information about how to create a certificate template, see Creating a Certificate Template.
Note: Client PFX certificates can be used on devices running Microsoft Windows 10 or later. This includes HoloLens for Business devices but not HoloLens devices. Hover over Applicable Editions in the dialog box for more information.
Client PFX certificates installed on older devices will be ignored.
Select from these available certificates and templates | Lists the currently available certificates and templates.
(Windows Modern Desktop and HoloLens for Business) Specify the type of certificate | Select whether you want the certificate to be installed in the Device store or the User store. |
