Feature Control: Android Enterprise
Hardware
| Disable Camera | When enabled, the device loses camera functionality. All apps in the Work profile will be prevented from launching the camera
Android OS compatibility: 6.0 or later. Available on Managed Profile only. |
| Disable Screen Capture | When enabled, device users cannot take and save an image or a recording of the device's display. |
| Disable Factory Reset | When enabled, device users cannot complete a factory reset of the device through the settings menu. Factory reset is still possible using hardware key combinations.
| Disable Safe Boot | When enabled, devices cannot be rebooted into safe boot mode (all third-party software is disabled in safe boot).
| Disable Smart Lock | When enabled, device users cannot use Smart Lock on Android which allows devices to unlock without a password when they are within 'safe' places that the device user sets.
If the Disable All Keyguard Features feature control option is enabled, Disable Smart Lock will be automatically enabled too. Android OS compatibility: 6.0 or later. Available on Managed Profile only. |
| Disable SMS | When enabled, the device cannot send or receive SMS.
Available on Managed Device only |
| Disable Status Bar | When enabled, the status bar cannot be expanded to view the details of device notifications.
| Disable Keyguard Camera | When enabled, the device user cannot launch the camera app from the lock screen.
If the Disable All Keyguard Features feature control option is enabled, Disable Keyguard Camera will be automatically enabled too. Available on Managed Device only. |
| Disable Microphone | When enabled, the device user cannot use the device microphone to record audio.
Cellular Data and Roaming
| Disable Copy/Paste between Work and Personal | When enabled, device users cannot copy text or images between the Work and Personal profiles.
Available on devices with work profiles only. |
| Redact Notifications | When enabled, notifications from Android Enterprise Apps are stripped of details when they appear on secure lock screens.
If the Disable All Keyguard Features feature control option is enabled, Redact Notifications will be automatically enabled too. Android OS compatibility: 6.0 or later. Available on Managed Profile only. |
| Disable Managed App Uninstallation | When enabled, device users cannot uninstall any managed applications. |
| Disable Third Party Input Methods | When enabled, device users cannot enable additional third-party input methods such as keyboards on their devices. Third-party input methods that are already enabled can still be used. |
| Disable Caller ID Information for Work Contacts | When enabled, device user cannot see Caller ID information for calls from contacts saved within the Work profile. |
| Disable Installation from Unknown Sources | When enabled, device users cannot install apps that are not from the Google Play store.
| Disable Multi-User Control | When enabled, device users cannot add (or remove previously added) secondary users.
| Disable Mounting Physical External Media | When enabled, device users cannot mount physical external media (including SD cards) to their devices. Physical media that are already mounted remain connected.
Available on Managed Device only. Note: This does not disable external media through the device's charging port. To accomplish that, use Disable USB File Transfer and USB Storage.
| Allow Sharing from Work to Personal Profile | When enabled, device users can use an app's Share function to share between apps on the Work profile to apps on the Personal profile.
Android OS compatibility: 5.1.1 or later. Available on Managed Profile only. |
| Disable Outgoing NFC | When enabled, devices users cannot use NFC to send data (only applies to apps in the Work Profile).
| Disable Bluetooth Contact Sharing | When enabled, device users cannot use Bluetooth to share contact information.
| Disable USB Debugging | Determines who controls the device's ability to enter USB Debugging Mode.
| Disable USB File Transfer and USB Storage | When enabled, device users cannot transfer data using a USB connection or save to a USB storage device.
This option is enabled by default. Available on Managed Device only. |
| Disable Certificate Management | When enabled, device users cannot modify stored Credentials (Certificates) in the device's settings.
| Disable Tethering Management | When enabled, device users cannot modify their device's tethering (sharing a mobile device's data connection with another device) settings.
| Disable App Management | When enabled, device users cannot uninstall or modify apps (and app data). This includes disabling the ability to force close an app, clear app data, app caches, and app default launch settings.
| Disable Bluetooth Management | When enabled, device users cannot modify their device's Bluetooth settings. Device users can still enable or disable Bluetooth.
| Disable WiFi Management | When enabled, device users cannot modify WiFi configurations in their device's settings.
| Disable VPN Management | When enabled, device users cannot modify their device's VPN settings.
| Disable Network Settings Reset | When enabled, device users cannot reset their network configurations from their device's settings.
| Disable Location Sharing for Managed Profile | When enabled, Location Sharing is disabled in all Managed Profile apps. Apps running in the Work profile will be unable to use device location information.
| Disable Outgoing Cellular Phone Calls | When enabled, device users cannot initiate outbound calls. Internet or Voice-over-IP (VOIP) are not blocked.
| Enforce minimum WiFi Security Level | Set the minimum Wi-Fi Security Level that the device can connect to. For example, if you set the minimum Wi-Fi security level to WPA, the device will not be able to connect to a WEP network.
| Skip App First Use Hints | When enabled, when a supported app launches for the first time, it will skip any introductory hints or tutorials. |
| Disable All Keyguard Features | When enabled, device users cannot use any keyguard features from the lockscreen. Keyguard features include fingerprint authentication, viewing of notifications, smart lock access and camera access. Enabling Disable All Keyguard Features will automatically enable the other keyguard feature control options.
| Disable Fingerprint Authentication | When enabled, device users cannot use Google's fingerprint authentication framework to secure their devices.
If the Disable All Keyguard Features feature control option is enabled, Disable Fingerprint Authentication will be automatically enabled too. Android OS compatibility: 6.0 or later. Available on Managed Profile only. |
| Disable All Notifications | When enabled, all notifications on secure lock screens are hidden from device users.
If the Disable All Keyguard Features feature control option is enabled, Disable All Notifications will be automatically enabled too. Available on Managed Device only. |
| Disable Account Creation | Prevent device users from adding new accounts to the device. Choose an option from the dropdown list
This does not remove any existing accounts from the device. All Accounts is selected by default. |
| Disable Doze Mode | When enabled, the device agent overrides the Android doze mode feature to remain continuously connected to SOTI MobiControl. This option negates any battery optimizations provided by doze mode and will use additional battery power to stay connected. |
| Disable all System UI | When enabled, system UI alerts will not appear to device users. This includes toast messages, phone activities (including priority) system alerts, system errors and system overlays.
| Disable Verify Apps Enforcement | When enabled, the device user can change the Scan device for security threats option within the Play Protect settings of the Google Play Store. If Disable Verify Apps Enforcement is not enabled, the Scan device for security threats option is enabled on the device and the device user cannot modify it. |
| Perform SafetyNet check on Device Check-in | When enabled, the SafetyNet check is performed on the device at every device check in, in addition to once daily. |
