Factory Reset Protection
| Add | Select to open the Add Google ID dialog box where you can add new Google IDs and their associated email accounts. |
| Edit | Select Edit while a Google account ID is selected, to open the Edit Google ID dialog box where you can modify the Google ID or its associated email. |
| Delete | Select Delete while a Google account ID is selected to delete the selected Google ID. |
| Disable Factory Reset Protection | When enabled, devices will not prompt users to enter credentials to unlock the device following a factory reset.
Note: If a device is targeted by two profiles with conflicting Factory Reset Protection settings, the Disable Factory Reset Protection setting will take priority.
