Options
Use this tab to specify profile assignment options.
Select the profile installation method.
Installation Method Choose how the profile's content are installed on the device:
  • Automatic: the contents of the profiles are automatically installed on the device once the profile is received.
  • Self Server: the device user chooses which configurations or packages to install.
Package Options
Select options for package storage on the device, when package installation or reinstallation should occur, and when the package should be uninstalled.
Note: This section is only visible if the profile contains a package.
Store Packages persistently when supported by device When enabled, packages are stored persistently on the device
Reinstall packages on every update schedule and check in When enabled, packages are reinstalled on the device on every check in.
Uninstall package contents upon profile revocation or deletion When enabled, package contents are removed from the device when the profile is removed or deleted.
Install Package Date Set a date and time for the package to be installed on the device. Choose which time standard to use: Device Time or UTC Time
Restrict package installation to the specified time frame Set time frames during which packages can be installed. You can set multiple frames. Click Add to add a time frame. Click Edit to edit an existing time frame.
Profile Scheduled Actions
Specify the time and date on which the profile will be assigned, disabled, or revoked.
Assign Date Enable to select a date and time to assign the profile. If you also enable Delay to next update schedule, the profile will be assigned on the first update check in following the Assign Date.
Disable Date Enable to select a date and time to disable the profile.
Revoke Date Enable to select a date and time to revoke the profile.
