Managing Certificates
You can install digital certificates on your devices using profiles. In addition to specific certificates, you can use SOTI MobiControl to generate new certificates based on Certificate Templates.
Certificate Authorities
SOTI MobiControl supports the following certificate protocols:
  • Active Directory Certificate Services (ADCS)
  • Entrust
  • Generic SCEP
Certificate templates can generate digital certificates that are dynamic for each user and device. Certificate templates can be based on:
  • Enrollment User*
  • Enrollment User Email Address*
  • Device Name
  • Device MAC Address
  • Device Serial Number
  • Device Platform
Note: * It is recommended that you enroll your devices with LDAP to use Enrollment User or Enrollment User Email Address effectively.
