Manual Approval
To manually approve devices in SOTI Connect:
				On the menu bar, click the main menu button and select Alerts.
				The Alerts view opens, and in New Devices you can see the list of discovered devices waiting to be approved.
				In the right pane, hover over the device you want to add and click the Approve button on the right side of the row.
				Tip: You can also use the Approve All button on the top-right side of the pane to add all the devices at once.
You have now successfully approved the devices. You can find them in the Devices view, ready to be added into groups, rules, or reports you may have defined.
