Branding the Administrative Console
You can select a custom logo to appear in the top navigation bar of the SOTI MobiControl console.
Note: A transparent, rectangular image is recommended. The image will be scaled to 32px in height. The maximum file size is 1 MB.
			To select a custom logo:
- From the Settings tree on the left, select .
				In the Administrative Console page that opens (see Administrative Console), remove the current logo (if any):
				- Click the Delete icon displayed over the current logo.
- Click Delete in the confirmation message that appears.
				Do one of the following:
				- Click the Browse File link in the Custom Logo field, then browse for an image file for the new logo.
- Drag an image file for the new logo and drop it into the Custom Logo field.
- Click Save.
