Configuring the Self Service Portal
To add branding or to modify device behavior when unenrolled through the Self Service Portal:
  1. On the All Platforms tab, select the Servers tab.
  2. Under Global Settings, click the wrench icon beside Self Service to open the Self Service dialog box.
  3. Modify the fields as desired.
  4. Click OK to save the new Self Service Portal settings.
