Sending Scripts to Devices
Use scripts to execute commands on your devices. You can send scripts to Android Plus, Linux, macOS, Windows Desktop Classic, and Windows Mobile/CE devices.
Note: SOTI MobiControl has several predefined legacy scripts ready for use such as activate connection, show message, and wipe device. You can use one of SOTI MobiControl's predefined scripts or create a custom script. For a full list of available legacy script commands, see Using Script Commands.
			To send a script to a device:
- Select the device or devices you want to send scripts to and click the Send Script icon in the Device Actions menu bar.
				Choose a script type:
- JavaScript: Allows you to use standard JavaScript language features to make changes to your devices. Only supported on Android Plus devices. Learn more at Android Plus JavaScript Scripts.
 - Legacy: Allows you to use SOTI MobiControl generated scripts to make changes to your devices. Supported on all devices that support scripts.
				Enter the script into the Script Editor. You can also select a saved script from the Please Select dropdown list.
				Click the full screen icon: to enter full screen editing mode.
 - Optional:
				Save your script for future use.
- Click Manage Scripts to open the Manage Scripts dialog box.
 - Click the Add New icon: to clear the Script Editor in preparation for a new script.
 - Click the Script Type icon: to select the correct script language, JavaScript or Legacy.
 - Enter your script in the Script Editor.
 - Click Save Script.
 - Click Close to return to the Send Script dialog box.
				Choose a delivery method for the script from the Delivery dropdown list:
Delivery Method Description SOTI MobiControl Agent Sends the script to the SOTI MobiControl agent. Platform Notification Service Sends the script to the device using the device's native operating system messaging system. SMS Sends the script to the device using the SOTI MobiControl Messaging service. Not all delivery methods are supported on all device types. - If applicable, click the warning message at the bottom of the dialog box to see which of the selected devices cannot receive scripts and why.
 - Click Send Script.
