Locating All Devices in a Group
To locate all devices in a device group:
- On the device group whose device locations you want to see, click to open its Group Information panel.
- Move to the Location tab.
SOTI MobiControl will automatically initiate a device locate request. Otherwise, click the Locate All icon.
Note: Only devices directly within this group will appear. Devices in nested groups are not included.
A colored dot for each device will appear on the map. Online devices are green dots. The color of offline devices varies depending on the last time SOTI MobiControl was able to gather location information for the device. Check the Last Located legend in the top left corner of the map for which colors correlate to time ranges.
Devices in close proximity appear as a cluster. Zoom in to see individual dots.
