Options
Use this tab to specify profile assignment options.
In the first section, select the profile installation method and (for Windows Desktop profiles) the minimum device battery level for assignment.
Package Options
Note: This section is available only when assigning a profile for Windows Desktop devices.
			In this section you select options for package storage on the device, when package reinstallation should occur, and when the package should be uninstalled.
Scheduled Actions
In this section you specify the time and date on which the profile will be assigned, any included packages will be installed (for Windows Desktop profiles), the profile will be disabled, and the profile will be revoked.
