Split Billing
The Split Billing configuration for Samsung KNOX profiles enables you to separate the billing and tracking of enterprise cellular data usage from a device user's personal cellular data usage. Once this policy is enabled, supporting carriers will set up separate billing information. This feature requires that the carrier supports Samsung Enterprise Billing, and that you have set up your account to enable this feature.
Note: To set up Enterprise Billing on a Samsung device, the device must support KNOX 2.2 or higher.
		| Access Point Name | Enter the name or web address of the access point provided by your wireless carrier. |
| Mobile Country Code | Select the three-digit code, as defined by the ITU, to identify the network's country of origin. |
| Mobile Network Code | Select the appropriate network code for the desired country. |
| Allow Data Roaming | Select this option to enable roaming data usage while in foreign coverage areas. |
