Add/Edit Application Run Control Entry
In this dialog box you specify the device restriction you want to add to the Application Run Control list.
Target Type Select the target type of the restriction.
  • EXE: Define a restriction for launching executable applications.
  • MSI: Define a restriction for executing Windows Installer files.
  • Modern Application: Define a restriction for running apps from the Windows Store.
  • Script: Define a restriction for running scripts.
Note: On Windows Phone, only Modern Application is available as the target type.
Policy Type Select the policy type of the restriction.
User or Group SID Enter the Windows user or group security ID you want the restriction to apply to, or select a predefined user or group security ID from the list.
Name Enter a name used to identify the restriction.
Description Enter a description for the restriction.
