iOS WiFi
With MobiControl's WiFi policy, we are able to configure the WiFi connection on iOS devices.
This offers a way to safely and quickly configure the wireless connection on one or hundreds of devices.
WiFi Policy dialog box
If more than one network is needed to be configured, selecting will create an additional profile.
Field Name Description
Network Name The name of the network which the device should connect to. Also is the name of the Wireless Policy.
Auto Join Network Selecting this will enable the device to auto connect to this network.
Hidden Network Select whether the network is hidden or not.
Security Type The security protocol currently being used on the network. We can select WEP, WPA/WPA2, Any (Personal), WEP Enterprise, WPA/WPA2 Enterprise, Any (Enterprise) or None.
Password The password to connect to the network.
Enterprise Settings If 802.1x Enterprise is selected as the security type, clicking the text box will bring up the Enterprise settings page. See below for more information on the Enterprise settings panel.
Proxy MobiControl offers proxies to be automatically configured, or to manually configure them. If automatic is selected, then enter a URL in the URL field. If manual is set, then we must enter data in the Proxy Server, Username, and Password fields.
URL If automatic is selected as the proxy setting, enter the URL of the proxy here.
Proxy Server If manual is selected, enter the name of the proxy server here.
Username If manual is selected, enter the username for authentication here.
Password If manual is selected, enter the password here.
  • Enterprise Settings
  • When any Enterprise option is selected as the Security type, click the Enterprise Settings text field. The following pop up will show.
    Enterprise Settings
    On the Protocols page, we can select TLS, LEAP, EAP-FAST, TTLS, PEAP and/or EAP-SIM.
    Clicking Authentication brings more options on how to configure the Enterprise settings.
    Authentication Settings
    Username Format The format which the user name should appear as. We can select UPN, Domain\Username, Username or we can prompt the user or use a static user name.
    Username If static is used, then enter the user name here.
    Use Per-connection Password When this is checked, a password will be
    Password If static is used, then enter the password here.
    Use Identity Certificate When a certificate is imported through the certificate manager, then we can select it through here. Please see the iOS Certificates page for more information on the Certificate manager.
    Inner Identity Inner Identity
    Other Identity Other Identity
    Trust Settings
    Once everything is configured, just click Save and close and the pop up will close.
If a wireless configuration is not needed anymore, just select . After all configurations are done, click .
© SOTI Inc.
Contact us
