Add API Client
Use the Add API Client dialog box to enter the information, and generate the required credentials, for a new SOTI XSight API client.
Name Enter a descriptive name for the new API client.
Redirect URL Enter the URL of the new API client. SOTI XSight will return an authorization code to the API client which can then use the code, along with the client ID (and optionally, the client secret), to request an access token from SOTI XSight.
Add & Generate Credentials Click this button to add the new API client and generate the client ID and client secret the new client will use to authenticate to the SOTI XSight API authentication server.
