A Device Status and Custom Data Event is an alert triggered based on an assortment of data values that you have set. See below for a full list.
Windows DevicesThe Device Status and Custom Data Events listed below are specific to Windows Devices.
Device Status and Custom Data Event Notification Selection Window The Operation and Value fields allows to filter out Alerts based on specific
values or value ranges. The Operation field specifies at which point an alert
will be created for the data value you have specified. Severity is set to Minor
by default and can be altered. The below table shows all available default Device Status and Custom Data Event events:
Select devices.Select the devices to which the rule will be applied. Apply the rule to all devices in your device tree or simply individual group(s) and/or device(s). Once you have completed this section, click the Next button.
Select Schedule.Select how frequently the devices should be checked for the requested Alert information. Once you have completed this section, click the Next button.
Select Actions.Select an existing notification profile, or click Profile to create a new Notification Profile. For assistance with notification profiles Click Here. Once you have selected your Notification Profile you can select a Device Side Action. This action is a script that will be launched on the device when certain criteria is met. For assistance with the Script Manager Click Here.
After selecting your Profile and Actions, click Next and continue the Alert Rule Wizard here.
iOS DevicesThe Device Status and Custom Data Events listen below are specific to iOS Devices.
Android DevicesThe Device Status and Custom Data Events listen below are specific to Android Devices.
After selecting your Profile and Actions, click Next and continue the Alert Rule Wizard here. |
