| Field Name |
Description |
| Account Name |
Enter the account name of your organization.
| Server Address |
Enter the server address of your organization.
| Use SSL Option |
This option allows the end user to select whether or not SSL is used for communication with the Exchange server.
| Domain |
Enter the domain name of your organization.
| User |
Enter the user name associated with your exchange account.
| Email Address |
Enter the email address associated with your exchange account.
| Password |
Check this box if you wish to have your password
saved. If this box is unchecked, you will be asked to enter the password
each time you perform synchronization. Also, this box must be checked for
push email synchronization.
| Sync Period |
Select the amount of time
for mail synchronization. |
