The following table describes fields in the Remote Control Settings dialog box.
Field Name |
Description |
Connection Profile |
Allows you to select the appropriate connection profile that you wish to use for your remote session. Auto is the defaul option and will use the inherited option.
Manufacturer |
Select the manufacturer and model of your device to have its skin be displayed in a remote control session. At this time Apple is the only Manufacturer of iOS devices.
Model |
The model of the device is determined by the Manufacturer. Select the model of the device from the list.
