Field Name |
Description |
Require Password |
If no user authentication is set. Any user can access the mobile
device without any authentication |
Allow repeating, ascending, and descending values |
Allows the user to create a password that contains repeating, ascending, and descending values, such as 1234, or 1111
User must select an alphanumeric password |
Requires the user to have numbers and letters in their password.
Minimum password length |
Requires the user to have a minimum password length
Minimum number of special characters |
Requires the user to have number of special characters in their password
Field Name |
Description |
Maximum Password Age |
Requires the user to change their password after the specified amount of time |
Number of Unique passwords |
Specifies how many passwords must be unique before the same password can be used again
Field Name |
Description |
Auto Lock |
Specifies how long before the device will lock after inactivity |
Password Lock |
Specifies how long the device can be locked for before requiring the user to re-enter their password
Maximum # of failed attempts |
Specifies how many time an incorrect password can be entered before the device is wiped
