Device group permissions allow for the segregation of MobiControl management privileges based on the device tree structure. For example, a support team operating out of California may be responsible for supporting all the devices in the western states, while another team out of New York is responsible for controlling all the devices in the eastern states. Using device group permissions, the members of the two respective teams can be granted varying levels of access to the devices in their own region (i.e. full access), and those in other regions (e.g. no access). To enable group permissions, you must first enable the MobiControl Manager Console user security. (Please see the Manager Console User Security page.) Once the Manager Console user security is enabled and configured, right-click on a group for which you would like to implement permissions and select Group Permissions. ![]() Selecting "Device Group Permissions" in MobiControl Manager
If the user or group belongs to the local domain, then the domain is not needed
(i.e. you can type in just " From the Device Group Permissions dialog box, you can customize user access and permissions. For instance, if you would like a user to be able to do everything, then you would select Full Control. Alternatively, if you would like the user only to be able to remote control the device, then select only that option. These security settings are applied to the devices groups in MobiControl Manager and define what users can do at the device level. The permissions in the group permissions page can be set at the group level, as well as the individual user level. The permissions will take the most restrictive settings. ![]() Device Group Permissions dialog box Important: If Allow is NOT selected, then the permission is not present and therefore not assigned to the user/group (as there is no deny option). However, if the permission is granted based on group membership, then the appropriate permissions are applied to all users within that group. Once the permission has been given on the group level, the permissions CAN NO LONGER BE DENIED.
