| Field Name |
Description |
| Install immediately after download |
If this checkbox is cleared, the installation of a downloaded package will be delayed till the specified Installation Date. The Installation Date must be after the Activate Date.
If a package depends on another package that is scheduled to install at a later time, then the Deployment Server will not push the package unless it is also scheduled to install at the same time or later.
| Push Packages As Soon As Possible |
By default, packages will be deployed to the devices according to the device synchronization schedule.
The device synchronization schedule is specified by the add devices rule used to add the device to MobiControl.
If this option is selected, package(s) will be deployed to the target devices immediately.
If the devices are currently offline, the package(s) will be deployed as soon as the device connects to MobiControl. |
| Network Restriction |
Restrict whether package deployment should take place over cellular data
networks.
| Persistently Store Package(s) |
For devices with stable storage, persistently storing packages allows them to be reinstalled after a hard reset, without needing to connect to the Deployment Server. |
| Uninstall Contents upon Rule Deletion |
This is relevant when the rule has been deleted or is no longer assigned to a device, for instance because it was moved to a new group or the rule
was edited to target a different group. - If Yes is selected, the package will be removed from the device, and the uninstallation logic of the packages will be executed.
- If No is selected, the package will be
removed from the device, but no uninstallation logic will be executed.
The uninstallation logic depends on what the package contains, for example, when a rule that deploys a package containing a .cab file is deleted.
- If the Uninstall Package(s) upon Rule Deletion option is set to Yes, the application installed by the
.cab file will be removed.
- If the Uninstall Package(s) upon Rule Deletion option is set to No, the application installed by the
.cab file will remain installed.
| Always Force Reinstall |
Packages will be
reinstalled on to the device regardless of whether they are already installed.
| Rule Priority |
This option allows you to prioritize the deployment of the
package(s).
Package dependencies (introduced in version 3.06) are
the recommended means to ensure the order in which packages are installed
on the devices.
| Enable Rule |
If you wish to activate the rule, that is, to install
the package(s), then this field needs to be checked. This option is also made available by right-clicking the rule in the
Rules view (tab).
When you disable a deployment rule, MobiControl will attempt to uninstall the packages that
were being deployed by that rule. If the package(s) that were being deployed contained .cab files,
MobiControl will try to uninstall the .cab files as well.
