Samsung Android Application Catalog Android
To Deploy applications to Android devices, you need to create an Application Catalog Rule. The user will then access the catalog, using their device, to view and download available applications.
Google Android Tab
The six steps below describe how the Create Application Catalog Rule Wizard can be used to create an Application Catalog Rule:
  1. Start the wizard.
    Select the Rules Tab, from the Google Android Tab, then Right-Click the Application Catalog Rules folder and select Create Application Catalog Rule. The first page of the Create Application Catalog Rule page will be displayed.
    Enter a descriptive name for the Application Catalog Rule you are creating and choose a Banner Graphic, then click Next.. A Banner Graphic must be 2100 pixels by 65 pixels and must be a picture file (Jpeg, Jpg, png, and gif).
  2. First page of the Create Add Devices Rule Wizard
  3. Configure the device group.
    Device Group Selection page
    First, select to which device group the devices configured by this rule will be added. The dialog box below displays the current device tree. Select the group where devices need to be inserted and then click Next. After selecting a device group click on the Next button.
  4. Configure Applications List.
    Application Catalog List
    Click the Add button to add Applications to the Application Catalog list.
    Application Entry Page
    Section NameDescription
    NameName of the application added to the Application Catalog
    Package NameUnique Application Domain Identifier
    VersionCurrent version of the Application added to the Application Catalog List
    DescriptionDescriptive information of the Application
    CategorySelect between Android Market Application or Enterprise Applications
    URLGlobal Access URL or Application
    TypeSelect between Mandatory or Suggested
  5. Review summarized information.
    The Application Catalog Summary page summarizes the settings configured on the previous pages of the wizard.
    If you are satisfied with the configured Applications List, click on the Finish button to create the device rule, otherwise use the Back button to go to previous screens and make adjustments.
  6. Applications Summary Page
  7. Advanced Settings.
    The Advanced Settings button allows you to specify when the Application Catalog Rule is valid from.
    Once you have made the changes, click Next.
  8. Advanced Settings Page
  9. Application Catalog Preview
    Browse the Application Catalog preview to ensure all Applications have been successfully added.
  10. Application Catalog Page
    Note:
    In a production environment typically a trusted SSL certificate is used already, but during demo/evaluations it is common to use the MobiControl generated SSL certificate, which will result in the Android device not being able to download Enterprise APK's.
    If MobiControl is configured with a trusted SSL certificate (e.g. VeriSign, GoDaddy, etc.) then the Android device will be able to download Enterprise APK files.
