Device Status and Custom Data Event
A Device Status and Custom Data Event is an alert triggered based on an assortment of data values that you have set. See below for a full list.
Windows Devices
The Device Status and Custom Data Events listed below are specific to Windows Devices.
Device Status and Custom Data Event Notification Selection Window
The Operation and Value fields allows to filter out Alerts based on specific values or value ranges. The Operation field specifies at which point an alert will be created for the data value you have specified. Severity is set to Minor by default and can be altered.
The below table shows all available default Device Status and Custom Data Event events:
Log Event Alert Message Alert Message (Customisable)
Available Memory Available Memory
Available Storage Available Storage
Battery Status Battery Status
Cellular Carrier Cellular Carrier
Cellular Signal Strength Cellular Signal Strength
IP Address IP Address
SSID SSID
Wi-Fi Signal Strength Wi-Fi Signal Strength
Select devices.
Select the devices to which the rule will be applied. Apply the rule to all devices in your device tree or simply individual group(s) and/or device(s). Once you have completed this section, click the Next button.
Select Schedule.
Select how frequently the devices should be checked for the requested Alert information. Once you have completed this section, click the Next button.
Select Actions.
Select an existing notification profile, or click Profile to create a new Notification Profile. For assistance with notification profiles Click Here. Once you have selected your Notification Profile you can select a Device Side Action. This action is a script that will be launched on the device when certain criteria is met. For assistance with the Script Manager Click Here.
After selecting your Profile and Actions, click Next and continue the Alert Rule Wizard here.
iOS Devices
The Device Status and Custom Data Events listen below are specific to iOS Devices.
Select devices.
Select Schedule.
Select Actions.
Android Devices
The Device Status and Custom Data Events listen below are specific to Android Devices.
Select devices.
Select Schedule.
Select Actions.
Samsung Android Devices
The Device Status and Custom Data Events listen below are specific to Samsung Android Devices.
Select devices.
Select Schedule.
Select Actions.
