iOS Managed Domains
Managed Domains allows administrators to protect company data by classifying domains as managed. This feature is available on devices running iOS 9 or later.
Managed Domains
Email Domains
Managed domains in email provide a visual reference for which domains are managed and which are unmanaged. Managed domains are highlighted blue while unmanaged domains are highlighted red. For example, if a user sends an email to an unmarked email domain, the email address is highlighted red to notify the user that they are sending correspondence to external parties.
Safari Web Domains
Use the Managed Safari Web Domains section to configure Managed Open In applications. If a user downloads a file from a managed domain, it is opened using the managed application associated with that file type. In this way you can keep your data secure. This feature works on the Safari browser only.
To enable Managed Domains:
While on the iOS tab, click the Profiles tab then the button. In the Add Profile dialog box, select the Payloads tab. Click Add and select Managed Domains from the drop-down.
Remember the guidelines below when setting your domains:
Format Description
example.com Treat any path under example.com as managed, but not site.example.com/.
foo.example.com Treat any path under foo.example.com as managed, but not example.com/ or bar.example.com/.
*.example.com Treat any path under foo.example.com or bar.example.com as managed, but not example.com.
example.com/sub Treat example.com/sub and any path under it as managed, but not example.com/.
foo.example.com/sub Treat any path under foo.example.com/sub as managed, but not example.com,example.com/sub,foo.example.com/, orbar.example.com/sub.
*.example.com/sub Treat any path under foo.example.com/sub or bar.example.com/sub as managed, but not example.com or foo.example.com/.
© SOTI Inc.
Contact us
