iOS Air Print
The AirPrint feature enables you to configure AirPrint settings by inputting either Resource Path or IP address of the printer to be registered. Registered AirPrint printers are added to the user's AirPrint printer list, which users can select from their iOS 7 devices.
To access the AirPrint configuration dialog box, click the Add button in the Add Profile dialog box, then click AirPrint under the Other heading.
The "Printer Profile Name" will be the title of each profile. Configured settings can be changed at anytime by selecting the printer profile and editing the fields.
Field Name Description
Printer Profile Name The name you wish to display for this printer profile.
IP Address Specify the IP address of the AirPrint destination. The IP address can be either IPv4 or IPv6
Hidden Network Specify the resource path of the AirPrint destination. The resource path distinguishes different printers that are located at the same IP address.
© SOTI Inc.
Contact us
