MobiControl's iOS VPN configuration enables you to set up the VPN settings for devices. You can set up VPN for L2TP, PPTP, IPSec, Cisco AnyConnect, Juniper SSL, F5 SSL, SonicWALL Mobile Connection, Aruba VIA, or a Custom SSL connection.
To access the VPN configuration dialog box, click the Add button in the Add Profile dialog box, then click VPN under the Connectivity heading and select a VPN type.
Important:
VPN settings are only available for devices with iOS 5 or higher.
To create a new VPN connection click
and select the desired connection type.
Below we will go through each of the configurations for iOS VPN Configuration. Click the titles to reveal the information:
| Field | Description |
| VPN Name | The name of the VPN connection |
| VPN Server / IP Address | The server or IP address of the VPN connection |
| Domain | The domain of the VPN connection |
| Username Format | The format of the user name which is used for connecting. We can choose UPN, Domain\Username, Username, Prompt User, or static |
| Username | The username for authenticating the connection |
| Proxy | Configures the proxy used with this configuration. We can select None, Automatic or manual |
| URL | If automatic is selected, then enter the address of the proxy here |
| Proxy Server | If manual is selected, then enter the host name or IP address of proxy server |
| Username | Username for authenticating the connection |
| Password | Password for authenticating the connection |
| Authentication | We can select the type of authentication used here. The options available are Password or RSA SecurID |
| L2TP Secret | Enter the L2TP shared secret |
| Send all Traffic | Routes all network traffic through the VPN connection |
| Encryption Level | Set the level of encryption. We can choose Automatic, Maximum (128 bit) or none. |
| Field Name | Description |
| Authentication | Select the type of authentication used for this VPN connection. We can select Shared Secret / Group Name or Certification |
| Group Name | If Shared Secret / Group is selected, we can enter the Group name used for authentication |
| Shared Secret | If Shared Secret / Group is selected, we can enter the shared secret used for the group |
| Prompt for Password | If selected, the user will be prompted for their password |
| Enable Hybrid Authentication | Authenticate using secret, name, and a server-side certificate |
| Identity Certificate | If Certification is used, we can select the certificate used for identity here |
| User Pin Request | Request PIN during connection and send with authentication |
| Enable VPN on Demand | When enabled, VPN on demand will establish a VPN connection for specified domains and host names. |
| VPN On Demand Actions | We can select Always Established, Never established, or Establish if needed |
| Group Name | The group name used for authentication |
| Authentication | Select the type of authentication used for this VPN connection. We can select Password or Certificate |
| Password used for Authentication | If Password is selected, we can enter the password used for authentication |
| Realm for authenticating the connection | Enter the realm used to authenticate the connection |
| Role for authenticating the connection | Enter the role used to authenticate the connection |
| Identifier for the custom SSL | Enter the custom SSL VPN (reverse DNS format) |
The tables below provide a description of the configuration's settings.
| VPN Name | Enter a name for this VPN connection. The name cannot contain spaces or special characters. |
| VPN Server Hostname/IP Address | Enter the hostname or IP address for your VPN server. |
| Domain | Enter the domain that authenticates your VPN connection |
| Username | Enter a username.
You can use the following macros to specify usernames: |
| Target Domain | Enter the target domain. |
| Port | Enter the port number of your mobility server port, if changed from the default (5008). This option is only available when the Target Domain field has been completed. |
| Profile Name | Enter a unique name for this profile. Necessary if you plan to create several VPN profiles with the same server address. |
| Proxy | Select a proxy to be used with this VPN configuration.
None: Do not use a proxy. Do not fill out any of the fields in this section. Manual: Manually fill in the fields with the settings for your proxy. Automatic: Enter a URL that contains information for this proxy. |
| URL | Enter a URL with the settings for your Proxy
Only applicable on Automatic proxy setups. |
| Proxy Server | Enter the hostname or IP address of your proxy server.
Only applicable on Manual proxy setups. |
| Username | Enter a username that authenticates the proxy connection.
Only applicable when setting up a Manual proxy connection. |
| Password | Enter a password that authenticates the proxy connection.
| Authentication | Select the authentication method that this VPN connection will use:
Password: a static password is used for authentication. Certificate: |
| Password used to authenticate the connection | Enter a secure password that will be used to authenticate the connection.
This option only applicable when Password is selected as the authentication type. |
| Identity Certificate | Select an identity certificate from the dropdown. This certificate will be used to authenticate the VPN server. This option only applicable when Certificate is selected as the authentication type. |
| Validate Server | When enabled, the connection is only established once the authentication's server certificate is validated by the client.
| Server Suffix | Enter a suffix for the server. A connection will only be established if the server name ends with this value. This option only applicable when Password is selected as the authentication type. |
| Enable VPN on Demand | When enabled, the VPN automatically connects to or blocks certain domains or hostnames specified in the VPN on Demand Actions below. |
To add multiple VPN On Demand Actions, enter the settings for your first action and a new empty row appears.
| Integrated Parameter Name | Create a name for the integrated parameter. |
| Action | Set an action for the integrated parameter name:
Always Establish: a VPN connection is always established for this domain or hostname. Never Establish: a VPN connection is never established for this domain or hostname. Establish if needed: a VPN connection is established for this domain or hostname if a VPN connection is required. |
